Turn Signal flashing slowly - NCRS Discussion Boards
  • Dave C.
    • August 31, 2003
    • 82
    I have not driven my 1970 in a long time. I took it out yesterday and the turn signals are flashing extremely slowly. The left lamp appears to be burnt out and I will replace it, however that will not cause the whole system to slow down will it? I have a bit of a drive and wondered whether I should buy a flasher as well or ?
    Thanks for any assistance
    Dave
  • Joe C.
    • August 31, 1999
    • 4598
    Re: Turn Signal flashing slowly
    Dave,
    The flash rate depends on the current flow thru the flasher. The more current flow, the faster the element heats up and makes/breaks, and so a faster rate. It sounds like you have at least one bad/missing bulb per circuit. The flasher cans are matched to the rated current draw (i.e.:size and number of bulbs)of the circuit. It's possible that you have the wrong unit installed.
    Joe
    • Dave C.
      • August 31, 2003
      • 82
      Thanks Joe it is an aftermarket flasher of some kind I will take it out and check it out as well
      thanks again
      Dave
      • Jim T.
        • March 1, 1993
        • 5351
        Throughout my 36 years of my 70, I have replaced a couple of flashers. When the last one quit I picked up one at WAL-MART name brand BUSS I believe, and it works just fine. Nice thing about the 70, the flasher is no problem to replace because it is so easy to change.
        • Lyle24961
          Joe
          Lots of light problems if bulbs and the flasher don't help are caused by bad grounds. If the bulbs seem dim this is the way they look with ground problems. I have a 10' ground lead I hook to the battery and direct to a cleaned up place on the housing of the bulb and if it gets brighter you need to fix the ground.
          Lyle
          • Dave C.
            • August 31, 2003
            • 82
            Thanks to all I put a new flasher in and all is well
            Thanks again
            Dave
