paintremoval - NCRS Discussion Boards
paintremoval
  • ian paterson #32527
    paintremoval
    i am repainting my c2 i dont have access to a mediablaster unless i trailer the body 200miles.what brand of paintstripper should i use? i know there has been lots of discussion on this subject of paint removal.the body is of now and am planning on painting it off he frame.any helpful hints from you xperts much appreciated.
    • 15606
    Re: paintremoval
    Ian,
    As you mention, there has been lots of discussion on this subject and everyone, it seems, has an opinion.
    You might want to check the archives of the board for ALL those.
    • Jeff
      Re: paintremoval
      I, fortunately, haven't had to strip anything in 25 years but my experience is that no one chemical stripper is necessarily the best in every circumstance. Depending upon paint brand, age and condition, laquer or enamel, etc., certain strippers work better or worse than others you may have had success with in the past.
      I'd buy a gallon of a few different types and try them all before buying them by the case. I once had a 65 FI roadster with a green metalflake (and glassed in nose, flares and whaletail sculpted from Bondo, we used to call it the "GreenHornet" but it's probably someone's Survivor car now) that was absolutely immune to every single stripper made at the time (1976). I finally had to grind off the paint because it was so hard that it sanded like iron. I would have loved to know what the hell it was. (It wasn't Imron or Centari.)
      BTW, not all strippers remove primer so you may have to sand the primer off which is not all bad. It's less harsh on the glass and straightens the body a little, as well. Also, if you are aware of any old (but good) body repairs you don't want to redo, sand those areas, don't strip them as the stripper will loosen the repair (unless it is purely fiber and resin) and you'll have to do them over.
      JP
      • g.r.rogers
        Re: paintremoval
        Contact the professionals.www.countycorvette.com get their phone number and give them a call telling them what you have available and are capable of handling and would like some advise.I'm sorry I can't really help you and would regret giving you some bad advise.Good Luck,GRR#33570
        • eddie H
          Re: paintremoval
          Im in the process of doing the same thing. I had one of my ttops media blasted and in a few days Ill be using Captn Lees stripper (water based). I see which one works best.
          • Mark
            Re: paintremoval
            Eddie, Double check what's in that stripper just to be sure it's water based. I bought a gallon of the "Captain's" stripper at Carlisle 2 years ago without paying much attention to the active ingredients. Surprise! It contains lots of Methylene Chloride (MCL) which is very, very nasty and has low exposure limits. We use this at work everyday and don't go near it without a fresh air respirator. Needless to say, I sold the stripper and never used it. Soda or media would be the only stripping choice for me personally. Mark
            • eddie H
              Re: paintremoval
              I will take a look, the problem with the media is that it left a rough surface but the grey coat is still there. I dont know if this is normal.
              • Mark L.
                • January 1, 1996
                • 121
                Re: paintremoval
                Ian,
                I tried Cap't Lee's and it worked pretty well (this is a OUTDOOR activity), but it was expensive. I bought BIX stripper from the Home Depot, seemed to work just as well, was much cheaper and NO shipping costs! Be sure to rinse with lots of water and a stiff plastic scrub brush, you don't want to leave any of that stuff behind. Good Luck......Best regards from Connecticut, Mark
