Engine lift brackets for 68 BB..... - NCRS Discussion Boards
  • Terry F.
    • September 30, 1992
    • 2061
    Can anyone tell me what markings are found on the engine lift brackets for a 68 BB. I know there are markings but I just don't recall there shape ect. Any help is always appreciated. Thanks, Terry
  • Michael M.
    • February 15, 2007
    • 455
    Re: Engine lift brackets for 68 BB.....
    Not sure about markings but mine were missing and I got the lift brackets from Paragon.
    • Terry F.
      • 2061
      I was wondering about the original brackets though. Terry
      • Mark #28455
        Can only get to 2 cars right now
        My 1969 has no front bracket as it is a 435 HP car, but the rear bracket has a capital "M" about 3/16" diameter surrounded by a "C" about 1/4" diameter. It also differs from the Paragon piece as the original is a perfect rectangle with sharp 90 degree corners and the Paragon piece looks like somebody drilled 1/4" holes at each of the corners so each corner has a 1/4 circle cutout.
        My 1970 has only the front bracket - the rear is missing - and it differs from the Paragon piece that it has a 1/8" hole drilled in it and has the GM part number stamped into it.
        Most of my parts are in storage, but I also found another set of lift brackets from a 1970 454 and the front matches my 1970 above, the rear shape matches my 1969 (with the sharp corners) but it has an approx 3/8" capital "L" on it.
        Hope this helps,
        Mark
        • Terry F.
          • 2061
          Re: Can only get to 2 cars right now
          Mark, thanks for the responce. Terry
