87 oil pressure sending unit location - NCRS Discussion Boards
  • Chuck R.
    • April 30, 1999
    • 1434
    I'm attempting to locate the oil pressure sending unit for an 87.
    I found a unit down by the oil filter but don't know if this is it. This car also has the ability to switch over to "oil temp" so I'm wondering if this is the temp sending unit.
    Any help is appreciated.
    Chuck
  • Joe C.
    • August 31, 1999
    • 4598
    Re: 87 oil pressure sending unit location
    Chuck,
    1985 Shop Manual lists the following locations:
    Oil Pressure Sender-------top rear of engine
    Oil Temperature Sender----lower LH rear of engine, above oil filter
    Hope that helps.
    Joe
    • Joe C.
      • August 31, 1999
      • 4598
      Add On
      For 1985, the pressure sender has a tan wire, and the oil temp uses a dark green/white wire. Not sure if this is also true for 1987, but possibly so.
      Joe
      • Chuck R.
        • April 30, 1999
        • 1434
        Re: Thanks Joe
        That's what I figured, but he doesn't have a book yet.
        Thanks a ton Joe,
        Chuck
