C2 PositiTraction Oil - NCRS Discussion Boards
  • Garry E.
    • September 30, 2002
    • 240
    What is the preferred oil to be used in a PositiTraction rear end.....? Also, there doesn't appear to be a drain in mind (late '64)..... I guess you pour in the new oil over the top of the remaining old oil.....?
    Thoughts....
    Garry
  • Joe C.
    • August 31, 1999
    • 4598
    Re: C2 PositiTraction Oil
    Garry,
    Reference the thread below:
    1967 M-21 and Posi-Rear End Lube
    Posted By: Sal Inciardi #41717
    Date: Tuesday, 18 July 2006, at 9:37 a.m.
    • Gary S.
      • July 31, 1992
      • 1632
      Use a standard suction gun, available at most auto parts stores, to draw out the old. Reverse the process to put in new. Btw, add one container of GM brand positraction additive before you put in your new gear lube. You will find that there as many preferences for gear lube as there are Baskin-Robbins ice cream. Personally, I use Mobil 1 synthetic.
      Gary
