vent cable length - NCRS Discussion Boards
vent cable length
  • Mark H.
    • July 31, 1998
    • 384
    vent cable length
    How long is the LH vent cable for a '64 w/o AC? I've been putting the dash area back together and the cable I have seems way too long and has some major bends in it, making operation difficult. Thanks.
  • Wayne M.
    • March 1, 1980
    • 6414
    C2 LH Kick Panel Cable is 17" measured ...
    from where the knob meets the under-dash bracket (when pushed in) to the center of the hole on the clip that screws to the plastic vent housing. This is from a non-C60 1965 [I just happened to have the cable on the bench], but should be the same (except for the knob shape, as your '64.
    • Mark H.
      • July 31, 1998
      • 384
      Hmmmm...
      Thanks Wayne. Mine is 17.5 inches, and I can attribute the difference to the clip placement. This suggests mine is so badly kinked that it won't work any more. It makes a big "S" with some pretty sharp curves.
      Mark
      • Wayne M.
        • March 1, 1980
        • 6414
        The S-Curve is OK
        Do you have a copy of the AIM ? cable goes straight forward from knob, then curves 90 degrees to the left to cross the hood release cable (doing this from memory -- don't have mine handy) to which it attaches with a clip that holds it in this angle; then another S-curve as it approaches the kick panel plastic vent cover.
