C1 exhaust manifold question... - NCRS Discussion Boards
  • Dave Suesz
    since Chevy has seen fit to discontinue the early exhaust manifold gasket kit, which actually fit the outer and especially inner edge of the 265 cylinder head, is there any other source of gaskets which even come close? I have some pitting which makes me leery of using no gasket. It would be best, then, to use something which actually fits, instead of the common over-the-counter gaskets which are labeled to cover "55-95 265-283-327-350-307-400 cid". That's a pretty wide target that requires a large opening, which means very little seal surface is avaialble on the gasket.
  • Mike M.
    • May 31, 1974
    • 8388
    Re: C1 exhaust manifold question...
    why not take the exh manifolds to a machine shop and have them broach or mill them true, then ya won't need a gasket. mike
    • Dave Suesz
      That'd be nice, except
      I did- the imperfections are now on the cylinder head. :o(
      • Mike M.
        • May 31, 1974
        • 8388
        Re: That'd be nice, except
        if the heads are off, why not machine them true also? mike
        • Mike McKown
          Go see your Ford dealer. Rotunda has a service two part epoxy that was used to seal porous automatic transmission castings.
          Clean the head/manifold surface. Apply a light coat of epoxy and bolt the manifolds on. Let it sit overnight and drive off the next day.
          Done it many times but I won't tell you where or when.
          • Dave Suesz
            Well, actually...
            the engine is in the car, and runs better now than it has in my living memory, and I've been riding around in this car since I had to stand up to see out the windows, that was a LONG time ago, so I ain't touchin' it.
