C1 exhaust manifold question... - NCRS Discussion Boards
  • Dave Suesz
    since Chevy has seen fit to discontinue the early exhaust manifold gasket kit, which actually fit the outer and especially inner edge of the 265 cylinder head, is there any other source of gaskets which even come close? I have some pitting which makes me leery of using no gasket. It would be best, then, to use something which actually fits, instead of the common over-the-counter gaskets which are labeled to cover "55-95 265-283-327-350-307-400 cid". That's a pretty wide target that requires a large opening, which means very little seal surface is avaialble on the gasket.
  • Mike M.
    • May 31, 1974
    • 8388
    Re: C1 exhaust manifold question...
    that 58 at proteam ought not to have a 265 ci sbc as your post would seem to indicate.mike
    • Dave Suesz
      Ahh, that photo was
      inadvertently attached by my "cookies".
