56 Wonderbar - NCRS Discussion Boards
56 Wonderbar
  • Jeff H.
    • December 1, 1988
    • 6
    56 Wonderbar
    The wife and I went to our favorite ice cream shop last evening. On the way home, turned on the old wonderbar and had nothing, no sound at all. There is power to the radio and speaker as far aa I can tell and the fuse looks OK The radio has not been turned on for about the last month. Also the radio was rebuilt almost one year ago. Where do I go from here other than pulling the radio & speaker and sending it out for repair ? Thanks in advance for your assistance.
  • Mike M.
    • May 31, 1974
    • 8385
    Re: 56 Wonderbar
    make certain the wiring harness from radio head to speaker assembly inmaking good contact--just wiggle it at the speaker head. a common cause of non-functioning wonderbars. mike
    • Roy B.
      • February 1, 1975
      • 7044
      Re: 56 Wonderbar
      If each are not grounded good to each other No workee!
      Yes! Radio too!
      • Robert S.
        • July 31, 2004
        • 377
        Re: 56 Wonderbar
        Hey Jeff,
        If Mike or Roy's suggestions didn'y help and you want to do some troubleshooting here is a link to a site that might help you out.
        Good luck,
        Bob
        Old radio troubleshooting
        Bob
        • David B.
          • July 31, 2004
          • 330
          Re: 56 Wonderbar
          Jeff,
          Check your antenna cable also. I had the same symptoms. If it is the cable, the radio is likely to scan forever, without stopping, because it cannot find a signal. The radio will not generate any sound to the speaker. Just disconnect the antenna on each end and run an ohm check on the cable with the help of a jumper wire.
          David
          Dave, 1969 427, 1957
          Previous: 1968 427, 1973 454
