C1: Emblem fastener - help - NCRS Discussion Boards
  • Dave F.
    • June 30, 2004
    • 443
    Every time I try to do something myself I run into these kinds of things. Can someone please tell me which of these (if either) is the correct fastener for the rear emblem bezel. Thanks.
    -Dave
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1: Emblem fastener - help
    left
    • James F.
      • December 1, 1985
      • 596
      Re: C1: Emblem fastener - help-Dave
      Dave, For '56 neither is correct, For most of '57 I believe neither is correct. Although the'57 JM states that the round speed clip is called for. I'm at issue with that statement. IF the round speed clip was used at all it would be late '57. I did some research on this round cllip and the drafting drawings were dated late '57. I don't want to get into an contestt hat drawing dates don't necessary indicate the intro of the part. I agree but un till something better comes along, I'll continue to believe that '56-'57 emblem fastners were the recatagular speed clip variety. Years beyond '57 I'm not familar withthe emblem fastners Regards, Jim
      • William C.
        • May 31, 1975
        • 6037
        what year car? *NM*
        Bill Clupper #618
        • Dave F.
          • June 30, 2004
          • 443
          Re: what year car?
          oops, sorry about that, it's a '59.
          -Dave
            • May 31, 1974
            • 8387
            Re: what year car?
            if its a 59 c-1, go with the speed nut on the right. as far as the left"thumb and forefinger butcher" is concerned, i put them on my 57's and will probably use it on the 56 as well. mike
            • Roy B.
              • February 1, 1975
              • 7044
              OK I changed my mind , can I do that??
              • William C.
                • May 31, 1975
                • 6037
                I'll tell you boys a small secret, it's the same part number nut in the '60 assy manual as it is in '62. If you check the '59 assy manual (I don't have one) and the number is 1174584, on section E sheet 3, it's the same in '59 and it's the one on the left.
                Bill Clupper #618
                • Roy B.
                  • February 1, 1975
                  • 7044
                  Re: C1: Emblem fastener - help "BILL"
                  OK Now I have to go back to my original answer "LEFT ONE" geeee can I do that again. If not I give up!!!!
                  • William C.
                    • May 31, 1975
                    • 6037
                    You are correct Roy! *NM*
                    Bill Clupper #618
