65 Alternator numbers - NCRS Discussion Boards
  • Martin T.
    • May 31, 2006
    • 196
    What is the correct serial number for an early 65 F.I.??
  • Wayne M.
    • March 1, 1980
    • 6414
    2 Possibles: 1100693 or...696 (w/T.I.) *NM*
    • Martin T.
      • May 31, 2006
      • 196
      Re: 2 Possibles: 1100693 or...696 (w/T.I.)
      My car is not a T.I. car. I was of the understanding that 95 or 96 were the correct numbers but, with an early VIN perhaps 93 is correct??
        Without T.I., you want an 1100693.
        • Wayne M.
          • March 1, 1980
          • 6414
          693 was base 37 amp rated, used thru 1967
          or maybe even later on (what I am told are still refered to as) Corvettes. Fuel Injection, if no K66, didn't require any additional amperage. The 694 (55 amp) was for A/C cars without T.I.
          The 695 you mention is a 32 amp rated alternator which I believe was found on Corvairs and maybe other small cars.
