Tach Solenoid - NCRS Discussion Boards
Tach Solenoid
  • Sean Conway
    Tach Solenoid
    1969 Corvette I see it has 3 ports and understand that 1 is a vent but I don't know what one is the vent port?????
    Many Thanks
    Sean
    • 43221
    Re: Tach Solenoid
    Sean-----
    My recollection is that there are 2 "matching" ports (i.e. OD and length) on the solenoid. Those are the ones to which vacuum hoses are connected. The other "port" is the vent. I don't think it "matches" the other 2 with respect to OD and length. That's the one to which no vacuum hose is connected. Originally, there was a foam rubber filter covering this port. It may be long-gone by now, though.
    • Sean Conway
      Re: Tach Solenoid
      Great Thank you for your time
      Sean
