i'm ashamed - NCRS Discussion Boards
i'm ashamed
    • May 31, 1974
    • 8389
    i'm ashamed
    ashamed to ask this question but i've been going thru the parts books and shop manuals for an hour now and i'll be durned if i can find the location of the coolant temp sensor on a LT5 engine. hookin it up to the temp gauge and ole Willy will closer to completion. thanks guys, mike
    • 43222
    Re: i'm ashamed
    Mike-----
    I've got bad news for you. The LT5 engine coolant sensors are located UNDER the intake plenum. So, the plenum has to be removed to access them. There are TWO sensors-----one is for the dash gauge reading and the other is for the ECM.
    The sensors are side-by-side; the ECM sensor is the forwardmost and the gauge sensor is behind it.
      • May 31, 1974
      • 8389
      Re: i'm ashamed
      joe: thanks. i'd have given 1000 to 1 odds you'd be the individual to answer the question.where did you find the illustration? regards and thanks again. mike
        • 43222
        Re: i'm ashamed
        Mike-----
        Somehow or another, I came to be aware of this some time ago, probably via discussion with someone. However, I was able to confirm my recollection by referring to section 6E3-C1 (VIN J) of the 1992 Corvette Service Manual.
        • Dennis C.
          NCRS Past Judging Chairman
          • January 1, 1984
          • 2409
          If you'd have just stuck a 572 in the sucker...
          ...you wouldn't have to ask all these stupid questions... I'm not that crazy about Holley's, but I can kind'a fix one. Nobody can fix a cornputer. If its broke, Ya put it in the landfill. Your bud, Dipstick... Have a Beast on me...
