1965 Fuel Injection Spider - NCRS Discussion Boards
  • Pat Roberts
    Looking for a NOS fuel injection spider. GM Description: Distribution Line , Group Number 3.330 , Part Number 7017369 Any help or leads would be appreciated. Have tried a rebuilt unit and one aftermarket. They do not work correctly. Thanks
  • Mike McKown
    Re: 1965 Fuel Injection Spider
    I can't help but I'm curious what didn't work correctly about them? Wouldn't calibrate? Drivability problem?
    • Pat Roberts
      I had them each flow tested and they do not have the correct amount of flow. With the rebuilt spider the car loads up and fouls out the plugs and it would not even idle. The whole injection system has been rebuilt. The fuel pump isbeing rebuilt by a man here in Ohio who is supposed to be one of the best in the country. He is the one who did all the testing on the spiders
      and explained that they were not flowing correctly. He has cleaned and flow tested the original and thinks that I might be able to get away with running it for a while but advised that if I could find a NOS original it would be best.
      • John D.
        • December 1, 1979
        • 5507
        (Message Deleted by Poster)
        • Pat Roberts
          Hi John,
          Thanks for your response. I trust the rebuilder knows what he is talking about. He is rebuilding the high pressure pump. I'll have to talk to my partner to find out if he mentioned the spill valve and the accelerator pump.
          Been trying to digest evrything he has told us but this is my first experience with a fuelie.
          Pat
          • John D.
            • December 1, 1979
            • 5507
            Pat, You injection is in good hands for sure. Don't worry about it as he will solve your problem. If he can't no one can. John
