67 300 w/A.I.R. intake manifold bolt locations - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5138
    It's an original motor car, with intake removed in 1981. Plastic bag is labeled "intake manifold bolts." At least 1 is not original. My understanding (correct me if I'm wrong) is that one of the right-hand ones (3rd back?) has a threaded stud for mounting of the strap-type bracket for the diverter valve. Are there any others that should be studs like that, or are all the rest regular old intake manifold bolts?
    Thanks!!!
    Mike Ernst
  • Rob Dame
    Re: 67 300 w/A.I.R. intake manifold bolt locations
    Mike, A couple of years ago now I helped assemble a 66 350 HP with AIR. I think there was only one stud in the location you mentioned but there was also a clip that holds the chrome vacuum advance tube as well. I can't remember just how that clip attached. Rob
      • 43221
      Mike------
      Yes, the third intake manifold bolt position on the right side is occupied by a special stud. I believe that this stud was GM #3883980 but it's long-since discontinued. Also, the forward right side manifold bolt is longer than the others to accomodate the thickness of the AIR pump bracket which it also retains.
      • Mike E.
        • February 28, 1975
        • 5138
        Thanks for your responses--any idea what the head marking would be on the longer one?
          • 43221
          Mike-----
          I believe that "C" or "M" were 2 of the headmarks found on the longer bolt for the right forwardmost position. Very possible there were others, too.
