'60 timing/idle performance - NCRS Discussion Boards
  • Matt F.
    • June 30, 2002
    • 79
    My '60 has a newer Edelbrock carb, and NOM 350. With the timing set to 8 deg. advance, it idles nicely. When I pull sharply on the throttle linkage, it gives a "huff", hesitates like it's not getting any gas, and if I release the linkage quickly it goes back to a normal idle. It looks like the accelerator pump is working fine, I can see the gas coming out. If I very gently and slowly pull on the linkage, the hesitation is minimal and rpms go up normally. This is probably something real simple, but I'm not figuring it out...help!
    -Matt
  • Roy B.
    • February 1, 1975
    • 7044
    Re: '60 timing/idle performance
    Still Timeing
    • Mark B.
      • February 1, 2004
      • 138
      Matt, look for a vacuum leak. I'll bet it's at the base of the carb.
      • Roy B.
        • February 1, 1975
        • 7044
        Loosen the Dist hold down ,pull sharply again and again as you move the Dist to advance or retard a little at a time till the engine dose not stubble , tighten the hold down -- your done!!
