Cylinder number sequence - NCRS Discussion Boards
  • Charles K.
    • May 31, 2006
    • 90
    I am installing new dist. cap, rotor, plugs, points, condenser and ign. wires.
    Can someone please indicate how the cylinders are numbered so I can be sure that I have the cables correct. Thanks
  • William C.
    • May 31, 1975
    • 6037
    Re: Cylinder number sequence
    1357 drivers side, 2468 pass side, front of the car working to the rear. Remember the rotor in the distributor turn counter-clockwise and the firing order is 18436572 on a Chevy.
    Bill Clupper #618
    • Charles K.
      • May 31, 2006
      • 90
      Re: Cylinder number sequence-Thanks dude!
      Thanks for the info Bill.
        Charles -
        Here's the correct distributor orientation and wire indexing in the cap with the firing order; the rotor turns clockwise when viewed from above. Photo isn't of a Corvette, but it's the same configuration. Note that the #1 wire is immediately adjacent (clockwise) from the adjusting window.
        • mike cobine
          Intake C/N 18436572 - a lot of those
          I've seen this casting number listed for the intake on a lot of number-matching cars on eBay.
          It must have been a very common intake.
          • Dennis C.
            NCRS Past Judging Chairman
            • January 1, 1984
            • 2409
            Bill, I can't believe you indicated the dist turns CCW... Your friend, Dennis
            • Mike M.
              • May 31, 1974
              • 8396
              you got the ole boy dip.perhaps ole clup was sippin Jack when he composed the counterclockwise post. mike
              • William C.
                • May 31, 1975
                • 6037
                Not jack, but a little too many brown bottles.
                Bill Clupper #618
                • Mike M.
                  • May 31, 1974
                  • 8396
                  hey Clup, you going to Texas? if so, why not drop down to Cumberland for the Wed Nite Down on the Farm party then run to texas with the Cumberlanders. mike
                  • Steve Antonucci
                    Re: Intake C/N 18436572 - a lot of those
                    Yes, but the odd thing is that both big & small blocks use this casting number
