Interior Paint Help - NCRS Discussion Boards
Interior Paint Help
  • Joe Fisher
    Interior Paint Help
    I am redoing a 61 with red interior. the person before me painted all trim grey. What type of paint should be used on the fiberglass and the metal parts? I purchase the red dye from Corvette America and test sprayed a panel over grey primer. It can out flat and a completely different red then the original dash metal. Any suggestions? Thanks, Joe
  • Mark L.
    • January 1, 1996
    • 121
    Re: Interior Paint Help
    Joe,
    I'm reasonably sure the paint should be laquer, at least it is on my '58. The gauge housing, kick panels, heater/radio fiberglass, gas tank cover area and underside of the decklid/trunklid/trunk was all the same paint. Although I think on a '61 the whole trunk area is body color. Hope this helps.....Best Regards from Connecticut, Mark
    • Loren L.
      • April 30, 1976
      • 4104
      The DuPont sheet for 1961 calls out the red interior paint as code # 2967 acrylic lacquer.
      • Joe Fisher
        Thanks for your help. Joe
