Non Original Engine Block Identification - NCRS Discussion Boards
  • John M.
    • November 1, 1988
    • 170
    I need help identifying a GM small block curently installed in a 1962 Corvette. This is a non original application block, and probably an over the counter purchase. The engine pad is clean and unstamped. The casting number is 3959512. The casting date appears to be F 6 2. There is a clock cast on the block that may indicate the block was cast in Saginaw post some time in 1964, so the casting date may be 1972. All information I have indicates this is not a Corvette application block. Can anyone identify the correct GM model application, year, cubic inch, and horsepower of this mystery block?
  • Donald L.
    • September 30, 1998
    • 461
    Re: Non Original Engine Block Identification
    The website http://www.nastyz28.com/sbchevy/sblock.html indicates its a 327-250 HP
    cast in the years 62-63. Threre is no original vehicle application so its probably an over the counter replacement.
      3959512 was a very common 327 service block; what's stamped on the front pad?
      • John M.
        • November 1, 1988
        • 170
        There is nothing stamped on the front pad of this block, it is blank and clean.
        I had a hunch this was an over-the-counter service replacement block but I couldn't find any info about it. I believe my question has now been sufficiently answered. Thanks guys!
        Save the Wave .............
