67 BB radiator width - NCRS Discussion Boards
  • Brandon K.
    • April 1, 1997
    • 474
    Could someone please measure their radiator and let me know how wide it is? (ie from the inside of one side tank to the inside of the opposite tank).
    Thanks in advance! Brandon
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 67 BB radiator width
    Brandon, I`ll check it when I can, but if you have the radiator support its as wide as the mounting straps on the support.
    • Brandon K.
      • April 1, 1997
      • 474
      Thanks, Wayne. I mean from side to side, not front to back, tho.
      Brandon
        • 43232
        Brandon-----
        I don't want to speak for Wayne, but I believe that he is referring to the distance between the OUTER ENDS of the "U-shaped" upper radiator brackets. Since these brackets fit immediately next to the tanks, the distance between the OUTER ENDS is also the width of the core.
        • Brandon K.
          • April 1, 1997
          • 474
          Oh...."tanks" for clearing that up for me, Joe.
          Brandon
