1963 Coupe Weather Stripping - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    I plan on installing the weather stripping on a July 1963 coupe this evening. Are there any hints, tips, methods or 1963 only procedures that I need to know? I have installed weather strip on two roadsters, but never on a coupe and especially a 1963 with all the production running changes. The weather stripping for the doors have an out side corner that will be a good starting point. I have not measured the door weather strip or laid out placement, if the weather strip is longer than needed where is the seem located?
    Thanks for any help!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
    Re: 1963 Coupe Weather Stripping
    Ray -
    The butt joint between the ends of the door main weatherstrip is located at about the center of the bottom of the door.
