C2 - 63 Master Cylinder leak - NCRS Discussion Boards
  • Tom Groves
    Just figured out where the brake fluid went from my original (never serviced) master cylinder. Only after it sits in garage over the winter I notice that the fluid is down. Now it see a dark spot under the drives floor carpet - brake fluid. Bought a Bendix rebuild kit - will a rebuild take care of leak? What is cause of leak that only occurs during long (cold) downtime? Thanks
  • Jim T.
    • March 1, 1993
    • 5351
    Re: C2 - 63 Master Cylinder leak
    The seals are rubber and wear from use will prevent them from sealing.
    • Bob R.
      • June 30, 2002
      • 1595
      Wouldn't the cylinder require sleeving to correct the problem?
