66 big block ride height - NCRS Discussion Boards
  • Jerry Weidner
    I have a 66 427 w/o air that has the F41 option, can anyone measure the ride height from the center of the front front fender wheel opening to the ground. I have the engine out so I cannot measure per the AIM. It was sitting about an 1-1/2 lower in the front than the back with the engine in. I want to adjust the front end height before I put the engine back in. The rear end sits at a nice height about 25-1/2 " form the center of the wheel well opening. I know the F41 springs will make it sit lower was just curious how much lower it should sit.
    Jerry
  • Don 42616
    Re: 66 big block ride height
    Jerry, 247/8" My 66 427 has replaced shocks. Mabe not valid for you. Don
