intake manifold number\Joe Lucia - NCRS Discussion Boards
  • Dennis R.
    Infrequent User
    • April 30, 2001
    • 13
    Joe--in an earlier post, you mentioned that the intake for a 6869 was exclusive to the Corvette--I just came across a 68 big block with the following number--3963569. Is this the correct one?
    As always, thanks for sharing your expertise.
  • Mark #28455
    Isn't that the Holey intake?
    The 1968-69 pass cars all used a high rise cast iron intake. The Corvettes used a low rise Q Jet ALUMINUM oval port intake. For 1970-71 ALL Chevrolet BB used a low rise intake, the Holley rect port was for the 375/396 and LS6.
    Isn't the one you have a Holley intake? The ones with the intake ports numbered for the cylinders are the 1971(?) version.
    Hope this helps,
    Mark
      • 15601
      Joe Lucia is at Bloomington Gold show
      I'm not sure what his computer access is, but if I see him Sunday, I'll tell him to check the discussion board
      • Steve Antonucci
        Re: intake manifold number\Joe Lucia
        Mike,
        That intake is a 1970-71 L/78 & LS-6 ( SHP ) intake. I can't remember if you
        were hunting a Holley or Rochester intake.
        Steve
