IR gun . other uses. off topic - NCRS Discussion Boards
  • Don 42616
    I know this is going to sound not quite right but I also have a IR gun & am just CURIOUS if I could find out body temp by inserting in the Ear?
    After all people with children buy an intrument to see if there is fever that inserts in ear (W/O laser) .I had one. But maybe they do not operate in same way. Perhaps unhealthful. Any thoughts? M.D.s out their? Don
  • Kevin M.
    • November 1, 2000
    • 1271
    Re: IR gun . other uses. off topic
    Point it at what ever your smoking divide by 2 and this will be your body temp.
    Kevin
    • Randy Krohn
      I used to work for a major manufacturer of tympanic thermometers. I suspect that your IR gun may look at a different wavelenght of IR than the medical thermometers. The other key to the medical thermometers is that they must "see" the tympanic membrane, so a small tip is required. The resolution and accuracy required is also much greater than you'll ever see with your IR gun.
      On the other hand, it's a great way to find out whether you should put that hot cup of drive-through coffee in your lap!
      • Don 42616
        Thanks Randy for your insight. You were the exact person to answer this ?. Don
