c1 shifter knob - NCRS Discussion Boards
c1 shifter knob
  • Paul Bowers
    c1 shifter knob
    my 57 has a four speed and i have a ivory knob on the shifter, but i have read articles that the knob could or should be chrome, whats the scoop can it be either thanks
    paul
  • Verle R.
    • March 1, 1989
    • 1163
    Re: c1 shifter knob
    Paul,
    Exerpted from the 57 NCRS Technical Informatio Manual & Judging Guide:
    "Shift lever spherical knobs appear genarally as follows for all available transmissions: Early 56 to unknown point (approximately 2/22/56) used a white plastic knob. Later 56 production to early 57 production (approximately serial number 200) used a 1-1/2" diameter chrome steel knob : remaining 57 production appears to have reverted to white plastic. It should be noted that chrome knobs have been found on some later model 57's."
    So, it depends on when your car was built.
    I suspect it should have the white (ivory) knob.
    Verle
    • Mike M.
      • May 31, 1974
      • 8379
      Re: c1 shifter knob
      if your 57 's vin is high enough to have had a t-10 installed originally, it would have had a white shifter ball/knob. mike
