I R Gun useage - NCRS Discussion Boards
I R Gun useage
  • Chas Henderson #28127
    I R Gun useage
    Hi all, Where does one aim the IRgun to get the best reading? I have shot the lower hose, upper hose near the radiator and near the thermostat. Fun to play with, but trying to check my guage.
    Chasman
  • Michael W.
    • April 1, 1997
    • 4290
    Re: I R Gun useage
    Aim it at the thermostat housing. That way you'll know what your thermostat sees and reacts to.
    • Gary Schisler
      Re: I R Gun useage
      In addition, I aim my IR gun at the upper and middle of the radiator to compare the readings. I noticed my 72 was running almost to the 200 mark yesterday while driving. My IR gun confirmed that the thermostat housing is only showing about 185-190 and the radiator is showing almost a 20 degree drop.
      Gary
        Re: I R Gun useage
        Aim it at the upper radiator hose, just above the thermostat housing - that's a matte surface and will give a more accurate reading than aiming it at the housing; reflective surfaces will result in an inaccurate reading.
        • Andy #28359
          Re: I R Gun useage
          If you are checking your gauge, try aiming around the temp sending unit.
