69 alignment specs - NCRS Discussion Boards
69 alignment specs
  • dick foehringer
    69 alignment specs
    what book has the stock alignment specs in it, i cant find it in the chassis service manual. i must be blind. thanks, dick
  • dick foehringer
    Re: 69 alignment specs
    i found it but the tolerences are pretty large. anyone have a perferred setup? i just want it to handle ok for highway driing, nothing like a race set up.
    thanks, dick
    • William C.
      • May 31, 1975
      • 6037
      Look in "Specifications" Section 3. At the back of the book
      Bill Clupper #618
      • Dick W.
        • 10483
        The only area that I would deviate from the manual is the toe in. If you are running radial tires the toe needs to be very close to 0.
        Dick Whittington
          • 15594
          I also believe that with radials the rear camber can be set at 0 as well.
