Does anyone have any experience at installing the exhaust block off plates for the intake manifold? They come four in a set, and I am told that you should use one on each side of the gasket. When installed by the gasket manufacturer, they are tack welded together. What would I use to hold them together during installation? I thought about using a small amount of silicone, clamping the two pieces together, and letting it dry overnight. Once the manifold is installed, they shouldn't move or seperate. Your thoughts and suggestions are appreciated!
57 Intake Manifold
