Pad ## guys look at this - NCRS Discussion Boards
  • Roy B.
    • February 1, 1975
    • 7044
    OK here is a good one for you engine pad guru's, Double stamped ?, aligned straight?, broach marks? and what ever else that is discussed.
    It's pasted NCRS inspection years ago, but then who know's. It's my 67 327-350hp.
    Cant wait to read all the postings , have fun!!!
    It's a big Pic. Give it time , it may be worth it??
  • Steve Wallach
    Re: Pad ## guys look at this
    Well they almost got it right! (not really)
    Steve
    • Gerard F.
      • June 30, 2004
      • 3806
      Holy Catfish Roy, Is that for real
      Maybe the stamper banged his head against the 427 hood.
      Jerry Fuccillo
      #42179
      Jerry Fuccillo
      • Wayne W.
        • April 30, 1982
        • 3605
        Re: Holy Catfish Roy, Is that for real
        The hood fell on his head because the stand wasnt attached right.
        • Roy B.
          • February 1, 1975
          • 7044
          Yes it is real , the original engine and I can prove it , your going to have to trust me, but I know vary well many art going to, and I don't really care to argue with them. If you also look real close you see a shadow of the 4 and 5 above the numbers. I've seen this happen before on other Vetts, but not this bad. Like I said before I seem to always have the odd ball out Corvettes and this one having the hood and trim number off too that make many think the Corvette is S%$#* . That ! Again is OK , NCRS will never see it again any way.
          So what do you guru's think ? Lets hear it!!!!!!!!!!!!
          • Gerard F.
            • June 30, 2004
            • 3806
            Looks like it was stamped 3 times, and the guy was counting to 5 with 4 fingers Didn't they use a little rack that held the numbers together.
            Jerry Fuccillo
            Jerry Fuccillo
            • Don 42616
              I have seen a double stamp on a 66 & Al Grenning said "right as rain"
              • Mark #28455
                I guess you'll have to come clean...
                and just put the original L89 back into it so the pad will be stamped right!
                Just kidding!
                Have fun with your car,
                Mark
                • lyndon sharpton
                  I see all kinds of #s in that pad! Roy how come NCRS will never see it again? because of the pad?
                  • Dennis C.
                    NCRS Past Judging Chairman
                    • January 1, 1984
                    • 2409
                    Roy, You call it what you want...
                    ...whether it's a SB/BB hood, a Steel Cities Gray 55 or this pad, you're on your own. I wouldn't touch any of the 3 w/a 10'pole.
                    But as you note, I'm sure "you" can "prove it" ...
                    • Mark #28455
                      what would have happened if
                      the original engine blew at the end of the assembly line or in the parking lot at the factory? Would there be a "heavy repair" area to tackle this? Did they use the gang stamp or was a "new" engine hand stamped with a VIN derivative?
                      Mark
                      • Roy B.
                        • February 1, 1975
                        • 7044
                        Re: Pad ## guys look at this lyndon
                        No! Having my Corvettes judged is just not my thing, I did have it judged once , in the last 27 years but I really drive my vetts and as many know I install accessories. This 67 would start to many arguments about it as it has before (hood) and as you see the engine pad would also.
                        That is why I posted the pad to show that not all were perfect and people can say what they think happened with out me being a fended ,
                        It may help other !
                        • Roy B.
                          • February 1, 1975
                          • 7044
                          Re: Roy, You call it what you want...
                          Dennis
                          You always was good at attacking a person first ,rather then having a discussion as to why or how something may have happened .
                          As always I hope the best to you and your High NCRS status credentials
                          • Dennis C.
                            • January 1, 1984
                            • 2409
                            Roy, You are amazing... No response here. *NM*
                            • Gary #41345
                              Re: Roy, You are amazing... No response here.
                              OK, it was halfway thru the third shift and MaryLou was stamping and Max was standing right behind her doing what Max does best.......checking the alignment....a little imagination goes a long way!!
