67 flasher problem - NCRS Discussion Boards
67 flasher problem
  • Walt W.
    • November 1, 1998
    • 92
    67 flasher problem
    My flashers failed to work at a recent meet. All other lights passed. I replaced the flasher module under the dash, but that didn't help. I can hear
    the clicking sound but the dash indicators don't work either. They work OK with the directionals Please HELP!!!
    wALT wEEMS
    L71
  • Peter L.
    • May 31, 1983
    • 1930
    Re: 67 flasher problem
    Walt - Please clarify. Are you having problems with the turn signals or the hazard indicators or both?
    Both flasher units are located under the dash with the hazard indicator flasher on the fuse block and the turn signal flasher on the passenger side radio side panel. Let us know which one you replaced and someone will surely be able to help.
    Pete
    • Walt W.
      • November 1, 1998
      • 92
      Pete,
      Thanks for your help. I replaced the unit on the fuse block and the flashers now work great. Now I wonder where I can obtain a flasher unit that will pass NCRS. Any thoughts??
      Walt
      • Joe R.
        • March 1, 2002
        • 1356
        Try Chicago Corvette for a correct NOS unit. Check your judging guide first so that you know what you are looking for.
