The link below has two photos: one of the dash mounted park brake bracket and cable assembly; and a close up of the cable assy. There are three notches on the cable end and I'm trying to determine which one matches up with the notch in the bracket and is to be fastened with a clip on the interior side of the firewall. I'm assuming that it is the center notch, which in the picture is approximately lined up with the notch in the bracket. That would leave the notch on the left end to be fastened with a clip on the engine side of the firewall. The reason I ask, is that the clip I received for the engine side is a tad small for that notch. I can get another clip, I just wanted to make sure I had the hook-up correct.
Steve
Steve
