'70 windshield frame replacement--need dimensions - NCRS Discussion Boards
  • George W.
    • May 31, 2000
    • 544
    Well, the W/S frame looked okay until all the sealent and crud was removed. I am looking for every possible measurement to insure that the new piece is at the proper angle, height, etc.
    I did measure a few areas before disassembly, but I am not sure if the w/s frame was properly aligned---for instance, measuring from the top of the w/s frame to the top of the door jam yielded a 1/2" difference from driver's side to passenger side.
    Please advise where I can find these measurements. I have looked in the assembly manuel, resto books, etc. without success.
    Thanks, george
  • Jim T.
    • March 1, 1993
    • 5351
    Re: '70 windshield frame replacement--need dimensi
    How much of the windshield frame are you going to replace? I replaced the top piece, both top corners and removed fiberglass to replace the left and right cowl pieces on my 70.
    • George W.
      • May 31, 2000
      • 544
      Jim,
      At first it appeared that just the top left corner needed repair, but I decided to replace the entire w/s frame and the corner cowl pieces.
      I cut it just below the trim tag (looks like I can save the tag area). I really need some dimensions.
      Thanks, g.
      • Dan Bloemers
        I might use the new windshield to provide the proper dimensions. Is this a (hm..1970)T-top..removable hard top..convertible? The glass should overlap the pinchweld by at least a 1/2 inch. where the top meets the glass and the side windows roll up should give you a pretty good idea of where you need to be..better than factory..a custom fit..(I may be wrong..I'm just a glass guy)
