window regulator rebuild - NCRS Discussion Boards
  • Tom Sarno
    Would anyone be able to explain the proper prceedure to replace the large rivit that is in the center of the spring on a c-3 power window regulator? I bought a new one and it had no directions.
    Tom
  • Scott Marzahl
    Re: window regulator rebuild
    The proper way..hmm. It is just riveted in place and you will probably need to use a pneumatic air hammer with a riveting head since this is a pretty good size rivet to buck. However, I have seen them replaced by either Tig or Mig welding them in place too.
