C2 accelerator (throttle) rod - NCRS Discussion Boards
  • Mitch NCRS #40813
    Looking to identify the correct "chamfer" on a 1965 SB throttle rod. Should the threaded portion run all the way into the thicker section of the rod or do all GM rods have a thinner, unthreaded section before it returns to the full rod diameter? And how long should this mecked-down section be? Have seen several different configurations.
    thanks
    Mitch
  • Ed D.
    • December 1, 2003
    • 207
    Re: C2 accelerator (throttle) rod *NM*
    • Ed D.
      • December 1, 2003
      • 207
      • Ed D.
        • December 1, 2003
        • 207
        Looks to be 1/16 " between thread and full diameter. The reproductions I purchased( 2 ) are very different. The seem to have a MUCH larger gap not machined correctly.
        • Mitch NCRS #40813
          Thanks for input. Did you find anyone of repro manufactureres making it correctly?
          I see Chicago and Corv America have wrong one - also looks like Paragon may have some necked down as well
          Mitch
          • Ed D.
            • December 1, 2003
            • 207
            Mitch ... no I did not find a manufacture that did a correct one. I ended up finding a nice original at the NCRS Florida Winter Regional in Kissimmee, Fl. You might try www.tracyvette.com . They aways seem to have a good supply of original parts ... Ed
