Tri Power Smog set up question.... - NCRS Discussion Boards
  • Steve Wallach
    On my 68 427/435, I've got the motor and chassis pretty much done, but I'm not sure where the smog vaccum hose ties into the carb set up? Can someon help with this? There is a small (1/8th inch ID) rubber hose coming off the Smog Pump. Where is that supposed to plug in?
    Steve
    Re: Tri Power Smog set up question....
    Steve -
    I'm not a C3 guy, but I THINK that hose (from the diverter valve attached to the pump) tees into the hose that operates the choke pull-off diaphragm on the center carb, which is a full manifold vacuum source. Maybe someone else more familiar with them can confirm or correct.
      • 43239
      John and Steve-----
      Yes, that's where it connects.
      • Steve Wallach
        Thank you,
        Steve
        • Steve Wallach
          Hi Joe,
          I have a couple more questions hopefully you can help me out with.
          Is the "T" that the smog line ties into metal or plastic? If plastic what color should it be?
          Also, should the smog line go over the pod or under on the front Carb?
          Thanks again,
          Steve
          • John C.
            • January 1, 2005
            • 616
            The "T" is plastic. It is the exact same one as used on the carb vacuum pods. On my car the "T" is a milky clear/yellow color. The line runs over the top of the pod but I have no idea if this is the original routing of the line.
            • Steve Wallach
              Thanks John,
              My car came with a Gold Cad metal T, but it was in the Vacuum Pod line, but it is longer in each direction. It looks REALLY old, so I wasn't sure if I should use that or not.
              The AIM shows the line going over the front Pod, but it's a pretty basic drawing.
              Thanks again,
              Steve
