'66 orig small block starter rebuild - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    My '66 L79 has its' original (and I think unrebuilt) ..320 starter. After turning off the engine, with hot outside temperature, it sometimes struggles to turn the engine over when I go to restart it. What exactly should I look for in a rebuild kit, in an effort to fix the problem, and where might I find one. So far, I haven't found anyone in my area (S CAL) that carries one. I've been calling around looking for new bearings and brushes and haven't had any success.
  • Rob A.
    • December 1, 1991
    • 2126
    ADDENDUM....
    I'm not interested in having the starter cosmetically "restored" by anyone. I just want to replace those parts that might be causing the problem.
    • Chas Henderson #28127
      Re: ADDENDUM....
      Can you buy one at the local parts store, use the parts you need, then return the starter as the core. Might not be too expensive as it could be a $29.00 starter from the store.
      Chasman
      • Rob A.
        • December 1, 1991
        • 2126
        Re: ADDENDUM....
        Chasman,
        That's a good thought. I wonder if it would have to be another Delco starter for the parts to interchange...
        • Dick W.
          • 10483
          Re: '66 orig small block starter rebuild
          You will need a new set of bushings for the drive end and the communtator end plus a set of brushes. Take emory cloth and polish the communtator on the armature. You may have to undercut the insulators on the communtator slightly. If you do I have found a broked hacksaw blade does a very good job.
          The Carquest numbers on the parts are
          RX60 Brushes
          X4349 Front Bushing .720 long
          X4356 Front Bushing .500 long
          X4378 Rear Starter Bushing
          I am not sure which bushing that you need for the front, but at under $3.25 each, it would not hurt to order both.
          Dick Whittington
            • 43239
            Re: ADDENDUM....
            Rob-----
            1) Just about any starter that you purchase rebuilt for your application will be a Delco and it will have parts interchangeable with those in your starter;
            2) Most of the parts that might be required in a rebuild are available from GM:
            brush (4 required)------GM #1906495
            frame, commutator end with bushing------GM #1974157
            bushing, drive end-----GM #1923907
            drive--------GM #10470757
            3) Aftermarket kits are available; I've seen these in auto parts stores. I don't recall the brand name;
            4) Generally speaking, even if you rebuild the starter with all new parts for the commonly replaced items (described above), I think that you're still going to have the same problem. However, it's worth a try. These parts are not too expensive.
            • Rob A.
              • December 1, 1991
              • 2126
              Re: ADDENDUM....
              Joe,
              Assuming the problem I described is a result of high compression and hot temperature, what would fix the problem? The starter functions fine under normal conditions and only labors on occasion under the conditions described.
              • Rob A.
                • December 1, 1991
                • 2126
                Thanks Dick.... *NM*
                  • 43239
                  Re: ADDENDUM....
                  Rob------
                  I fought this same problem for years once-upon-a-time. I tried EVERYTHING to cure it. The only solution that was 100% successful was the installation of a remote (slave) solenoid.
                  • Donald M.
                    • December 1, 1984
                    • 498
                    Rob, I had he same problem during hot weather. It turned out to be the battery. I had it tested hot and it failed the load test. New battery cured it. Just my $.02.
                    Don
                    • John O.
                      • May 31, 1998
                      • 480
                      Hi Rob.
                      Just my 2 cents. I have a 56 chevy 350 semi-built engine. I was having the same problem.After driving awhile and then shutting off hot engine, it would drag when I tried to start it again. I solved my problem with a larger diameter battery cable. It cranks and starts quicker. Check your cables and maybe try replacing the positive cable and see if that helps. I know it help me.
                      Good luck.......John
