oil pan nut plate - NCRS Discussion Boards
oil pan nut plate
  • Ray C.
    • June 30, 2001
    • 1132
    oil pan nut plate
    I need to replace the oil pan nut plate. I believe that the plate was spot welded. What is the best way to remove and secure the plate with out using a spot welder and damaging the oil pan.
    Thanks Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Harry Sadlock
    Re: oil pan nut plate
    Ray, to keep th integrity of the pan and the plate (meaning external seal to avoid oil leaks), I suggest you grind the plate and make it thin. When completed, braze the new nut plate to the old one.
    Harry
    • Harry Sadlock
      The Nut Plate is Part Number 3723008, Chevy said it is now a discontinued part but there are 49 in the Michigan warehouse and a few in Arizona and New York. So if you need one or think you will time to order. They were $5.00 each.
      Harry
      • Ray C.
        • June 30, 2001
        • 1132
        Thanks Harry,
        I just purchased one (part number 3723008) from my local GM dealer for a grand total of: $3.78 and that includes the 8% NYS tax.
        Thanks for the advise!
        Ray
        Ray Carney
