1967 Bellhousing - NCRS Discussion Boards
1967 Bellhousing
  • Mark K.
    Infrequent User
    • June 30, 1999
    • 1
    1967 Bellhousing
    I have a question about a correct bellhousing for a 67 small block [L79]. Is the casting # 3899621 correct for this application? Or is this a 'big block' only casting number? I have been told that the 621 number is big block only. Any help would be appreciated. Thanks. Mark
  • William C.
    • May 31, 1975
    • 6037
    Re: 1967 Bellhousing
    BB only for the 621, unless you count later 350 engines that used the 11 inch clutch setup.
    Bill Clupper #618
      • 43236
      Mark------
      1967 small blocks used bellhousing GM casting #3858403. 1967-69 L-88/ZL-1 used this bellhousing, too.
      As Bill mentioned, for 1967-68 the 3899621 bellhousing was used for big blocks only as far as Corvettes go. From 1969-81, it was used for almost all Corvette applications except L-88/ZL-1 and 70-72 ZR-1.
