Heat risers - NCRS Discussion Boards
Heat risers
  • Gary #41345
    Heat risers
    Looking though my various Corvette supplier magazines I don't see any heat risers for sale? Where do you buy these?
    • 43236
    Re: Heat risers
    Gary-----
    They're real easy to find. Suppliers like Dr. Rebuild and Paragon both carry them, for sure. I'd bet that most of the other Corvette suppliers do, too. Most auto parts stores can sell you a heat riser for most applications. Also, most (but not all) Corvette heat riser valves are still available from GM. So, obtaining a heat riser valve for your application should be amongt the easiest of your parts acquisition problems.
    There are some exceptions, though. 55-56 heat risers are more difficult to find. Also, some of the later C3 heat risers may be configured differently and/or more difficult to find than most others. 1957 through about 1974 are very easy to come up with.
    • Gary #41345
      Re: Heat risers
      TY..Joe The effects on an engine with a froazen heat riser in the closed position would be?
      • Christopher R.
        • March 31, 1975
        • 1599
        Re: Heat risers
        1. Exhaust sounds funny.
        2. No power.
        3. No exhaust gas exiting the right tailpipe.
        • Joe C.
          • August 31, 1999
          • 4598
          Re: Heat risers
          Additional potential problems:
          Spark knock
          Fuel percolation
          Lean misfire
          • lyndon sharpton
            Re: Heat risers
            if you have one that is stuck, try spraying it with a high heat penetrating oil. to free it up.
              • 43236
              Re: Heat risers
              Gary------
              In addition to the symptoms described by others, a stuck heat riser is very easy to confirm----just check the position of the counterweight. While it may be possible to free up stuck heat riser valves, if the valve is old, the best solution is a replacement. That's because even if you free it up, it will likely stick again before too long. No sense battling this problem on a continuing basis.
              • lyndon sharpton
                Re: Heat risers
                Oh,
                that is not all ways the case that it will stick again! I would try and free it up first, lot of work to change it out.
                • Dave Suesz
                  GM sells a heat riser lubricant. *NM*
                  • lyndon sharpton
                    Re: GM sells a heat riser lubricant.
                    yeah,
                    that is what I use. real good stuff a little goes along way.
