'66 power antenna bracket bolt thread size - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    Anyone know the thread size of the 2 original bolts that hold the power antenna bracket to the plate with the weld nuts? I had to drill out the broken bolts and want to tap the correct size back into the weld nuts.
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: '66 power antenna bracket bolt thread size
    Rob -- pulled the top P.Ant mount bracket bolt off my '65 for this pic (was working in the general area anyway). It's a 1/4" diameter (7/16 indented head bolt) with a captive lock washer. Overall length is 0.915", and you can count the threads [which are 28 threads/inch pattern].
    • Rob A.
      • December 1, 1991
      • 2126
      Wayne,
      Thanks a lot, I appreciate it. I'll get a tap and rethread the weld nuts on my bracket. Thanks again...
        Richard Fortier is reproducing those bolts now - he showed me some from the first run off the tools yesterday at our Michigan Chapter Meet.
