where to find correct 78 tran. seal? - NCRS Discussion Boards
+ More Options
Posts
  • Doug F.
    • June 30, 2005
    • 136
    im needing to replace the speedo cable seal where it goes into the transmission, but my local chevy parts man says GM discontinued the part, im not big into restorations so can someone please advise where to find this part?? ecklers doesnt have it either,, HELP????!!!! thanks doug
  • Travis Williamson
    Re: where to find correct 78 tran. seal?
    Im still an amateur at this restore stuff and I cant gurantee this is the best place to get what you are looking for....
    but if you go to www.corvette-paragon.com and download their 68-82 catalog on page 18 I think you will find what you are looking for.
    Part numbers (depends on what all you need):
    7188K (gear fitting w/seal & oring) $10
    or
    10481 (just the seal) $4
    good luck
    • Dick W.
      • 10483
      Automatic transmission seal part # is 759024. This is a Carquest part #
      Dick Whittington
      • Doug F.
        • June 30, 2005
        • 136
        thanks guys!!!
