'67 weatherstrip fastners - NCRS Discussion Boards
  • Terry Freeman
    On the front of the door opening is an "L" shaped weatherstrip called an "auxillary weatherstrip". It's glued on and, in addition, has four push-in type fastners on each side. We have a small controversy here over what type of fasters those should be. A very knowledgeable Corvette restorer in the area swares they should be plastic. The Judging Guide indicates a metal fastner. What's right? HELP!
  • Gene M.
    • April 1, 1985
    • 4232
    Re: '67 weatherstrip fastners
    The original fasteners on my 67 are metal with a black finish. If you are carefull they can be removed and reused.
    • Terry Freeman
      Thanks Gene. With so many "experts" running around, it's easy to get confused!
