C3/Low Oil Pressure Reading - NCRS Discussion Boards
  • Gregory G.
    • July 31, 2001
    • 203
    Drove my 1970 LT1 today.Checked the oil it was full and clean.She started right up.Idled well 700-800 rpm's when warm.Oil pressure gauge was at 35.After driving about 5 miles, stopped at a light the gauge was nearly above zero.The car still was running perfectly.Gauge never went above 35 while driving.
    Oil Pump?
    The gauge was rebuilt by Corvette Specialties.
    What could be the problem?
    Greg
  • lyndon sharpton
    Re: C3/Low Oil Pressure Reading
    what weight oil are you using? also did you check your line?
      • 43234
      Greg----
      I don't really think that there's a problem. What surprises me is that the oil pressure was at 35 PSI at IDLE just after initial start-up.
      Anyway, before making any sort of judgement as to the engine component condition, you need to install a test gauge of known accuracy to see just where you're actually at. My recommendation is to install a 1/8" NPT "tee" in the oil pressure fitting on the block. Connect the existing oil pressure line to one fitting on the "tee". Connect the test gauge to the other fitting. Then, you can see where you're at and effectively "calibrate" the in-car gauge. I think you'll find that the in-car gauge reads somewhat low, especially at idle RPM.
      • Gregory G.
        • July 31, 2001
        • 203
        Valvoline 10W40.
        The line is connected properly and is full.
        • Paul O.
          • August 31, 1990
          • 1716
          Greg check my response to Dave Rifkin about his 69 fuel and oil pressure gauge problens his posting was on the 28th you may have the same problem with the copper tube. paul
