What IF C2 hood latch cable brakes? - NCRS Discussion Boards
  • Don 42616
    My 66 hood didn't spring open the way it usually does. (it did open). If a cable should break under hood does anyone know how to access the latches to open hood manually?? There has to be a way.
    I can not see how to do it? I oiled latches & took out 1/8" cable slack at R/H latch. Just a negative thought!! Don
  • Alan Drake
    Re: What IF C2 hood latch cable brakes?
    On drivers side remove the metal splash panels, then go up to latch and move handle back to release. I assume cable from inside to latch is the one that brakes. If this only releases the driver's side - then try same on other side. Better look at pass side latch to see what needs pulling/pushing, I'm not sure.
    Now that you have found a way to open, it will not brake!
