c3 rear caliper bolts - NCRS Discussion Boards
  • David M.
    Infrequent User
    • November 1, 2005
    • 19
    does anyone no the exact length of the two bolts that hold the caliper on, van steel shows it to be 1 1/8", I have found 1" and 1 1/4". my car does not have the Z07 suspension. this is for my 75 vert. thanks, butch
    • 43236
    Re: c3 rear caliper bolts
    David-----
    The front bolts are 7/16-20 X 1-1/4". The rear bolts are 7/16-20 X 1-1/8". For this application it's important to use the correct length bolts. The 1-1/8" length is not a common hardware store size. However, you can trim a 1-1/4" bolt to this length. For this application, always use a known-quality, SAE grade 8 bolt.
    • David M.
      Infrequent User
      • November 1, 2005
      • 19
      joe, thanks,, I looked in the assembly manual and it shows a part #3843384 this number is no longer good or available from gm. I looked again at van steel and they show 1-1/8 for front and rear?? the assembly manual shows 2 different #'s, but it does not show the size or the length. butch
        • 43236
        David-----
        GM #3843384 was never available in SERVICE; it's a PRODUCTION-only part. However, this bolt was 1-1/8" in length.
        The front caliper retaining bolt was GM #186645. It was never available in SERVICE, either. However, this bolt was 1-1/4" in length.
        The 1-1/8" long bolt will work for both front and rear caliper retaining bolts. However, it's not what was originally used for the fronts.
        • David M.
          Infrequent User
          • November 1, 2005
          • 19
          joe,, thanks again, I'll order some bolts on tuesday, on my car the L/H rear, one of the bolts backed out and now is MIA... you have cleared up the fog in my head,,, I want it RIGHT!!! thanks again and happy driving..
          david aka "butch"
