Mid-year glove box liner; repairing fuzzy stuff? - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7023
    Does anyone know how to repair or fill in a focal defect in the fuzzy stuff that coats the liner on the inside of a mid-year glove box?
    Gary
  • Gary B.
    • February 1, 1997
    • 7023
    PS: Or should I just buy a repro liner? *NM*
    • Dick W.
      • 10483
      Re: PS: Or should I just buy a repro liner?
      Check with John Waluk. He advertises in the services section of the "Driveline"
      Dick Whittington
      • Tracy C.
        • July 31, 2003
        • 2739
        Re: Mid-year glove box liner; repairing fuzzy stuf
        Gary,
        The technical term for the fuzzy stuff is "flocking". It's actually short hair like material. I once messed around with a applicator when I was in the mfg R&D group at Beechcraft. Unless application methods have changed, I don't think you will have good success patching in a spot.
        It all starts with brushing a thin layer of colored quasi conductive paste adhesive on the substraight. You then connect a ground wire to the coated substraight.
        The colored flocking particles are in a hand held quart sized container with a fine mesh lid. This container has a 12 v positive charge that also charges the particles inside.
        The container is held close to the substraight (lid near the substraight) and slowly rotated about an axis perpendicular to the lid. The static charge then causes the flocking particles to fly from container to the part and stick on end into the adhesive.
        In a hour or so the adhesive sets up and you vaccumn the excess flocking (that couldn't stab adhesive) from the part.
        Not sure how a person could ever patch in a spot inless the entire surface was stripped or sanded bare. The new adhesive would just glob up on the existing flocking otherwise.
        My quess is a new part would be cheaper.
        Good Luck either way.
        tc
        • Mike M.
          • May 31, 1974
          • 8385
          after reading your post, a dandy, i'd have to guess you got your PhD in flocking. regards, mikie
          • Tracy C.
            • July 31, 2003
            • 2739
            yea ...Imma flocking Post hole Digger (PhD) *NM*
            • Dave K.
              • November 1, 1999
              • 952
              Gary,
              I bought the repro liner. The repro is a good reproduction. Had a bear of a time fitting it into the glove box. Tight fit. Was happy with the results. I would think that the flocking would be difficult to repair especially on an aged liner --stuff tends to get funny with age.
              Dave K.
              • Jeffrey S.
                • May 31, 1988
                • 1882
                Gary:
                If you go to a good woodworking store like Rockler or a craft store you can buy flocking kits. This flocking is used on drawers in which you store silver and on jewelry boxes. You will have to remove the flocking from the piece you want to repair. Then you brush on an adhesive and, using the "shaker" that you can buy with the kit, you shake on the new flocking onto the adhesive. After it dries (overnight) you shake off the excess flocking and re-use on another project. I have used this on severel fiber boxes that are used over the jack on C-3's and it comes out perfect. Hope this helps.
                Jeff
                • Gerard Q.
                  • February 1, 2000
                  • 284
                  John Waluk does real nice work w/date stamping.
