Nuts and bolts and Top Flight - NCRS Discussion Boards
  • Randy G.
    • April 1, 2006
    • 358
    I just bought a 1957 Fuelie that has a 1998 Top Flight certificate. I had it looked at by someone from the 1956-1957 judging team in Maryland who told me if I wanted to get in judged again and get a higher score I need to replace a lot of the hardware underneath. A lot of it has the grade 8 markings on the heads of the bolts (which isn't a bad thing to know if you happen to be driving it a lot).
    My question is, I have the judging manuals, restoring guides, etc., but I don't see anything on identifying correct hardware. I see some bolt heads with letters on them like C and TL. Is there a source available to help me identify the correct hardware so I can take this car to the next level?
    Thank you.
    Randy Goodwin #45471
  • lyndon sharpton
    Re: Nuts and bolts and Top Flight
    Randy
    get the book chassis restoration guide by Joseph A Tripoli, Jr. also Paragon parts should have the bolts that you are looking for and need to replace.
    • Michael H.
      • December 1, 2004
      • 118
      Do you happen to know whether Mr. Tripoli's chassis restoration guide also covers bolts that should be used on a '55 Corvette. Thank you,
      Mike
      • lyndon sharpton
        Mike
        yes it covers the years 1953 through 1972.
