C- 2 radio - NCRS Discussion Boards
C- 2 radio
  • Bob R.
    • June 30, 2002
    • 1595
    C- 2 radio
    I am having a reception problem on my radio. The car is a 63 with a correct 63 am fm radio. I had the radio rebuilt a couple of years ago. The radio seems to work correectly however the reception is very poor.
    On am I only get a couple of stations and I have to turn the volumn up quite a bit, fm is worse.
    I have a correct antenna. The antenna wire is a replacement wire.
    I'm thinking it must be a bad ground or a bad antenna wire.
    Thought I might get some good suggestions on testing here.
    As alwayls thanks to all for the assistance.
  • Joe C.
    • August 31, 1999
    • 4598
    Re: C- 2 radio
    Bob,
    Have you adjusted the antenna trim? This is set by tuning to a weak AM station around 1200 on the dial, and turning the adjusting screw for max volume. I am almost sure that this requires removal of the radio.
    Joe
    • Harry Sadlock
      Re: C- 2 radio
      Bob, as Joe suggested, adjust the AM side of the antenna. On a 63 the adjustment screw can be accessed by removing the right side radio cover. Have the antenna all the way up when you make the adjustment. As I recall the FM side is just antenna height.
      Harry
      • Frank C.
        • January 1, 1986
        • 277
        Re: C- 2 radio
        Bob....I had exactly the same problem as you and it turned out to be a faulty antenna wire (brand new reproduction from Corvette Central)...Good Luck
