Keys - NCRS Discussion Boards
Keys
+ More Options
Posts
  • Greg D.
    • June 30, 2004
    • 62
    Keys
    Where can I find replacement "original" ignition keys for mid year? I have the original door key but not the ignition.
  • Gary S.
    • July 31, 1992
    • 1633
    Re: Keys
    The Driveline! Every month a fellow adverises original keys. Jesser's Classic Keys. 330-376-8181. Definetly not cheap but he has them. I talked with him at Carlisle a while back and he does have an impressive collection. Oth, if you are looking for functionality, that is a totally different question.
    My opinion is that the point value of original keys, used in judging, does not justify the cost. Just my 2 cents.
    Gary
    • Ralph S.
      • February 1, 1985
      • 935
      Re: Keys
      The door and the ignition key were the same. The ignition must have been popped at one time and the new cylinder was not keyed the same as the original. Which is what was done in the old days.
      • Dick W.
        • 10483
        Re: Keys
        Give Pat Krause at Pat's Locks a call. 410-879-9647
        Dick Whittington
        • Joseph T.
          • April 30, 1976
          • 2074
          Re: Keys
          I don't know how authentic these are ..but checking Ebay for parts for my 59 Buick..there is a guy advertsing pairs of GM key blanks for $5.00.
          Always do your homework first.
          Check item # 4642048603
          Joe
          • Harry Sadlock
            Re: Keys
            Greg, use Pat Krause as Dick suggested. He is easy to work with, quick turn around and very good pricing. If you want to have the door key be the master, remove the ignition lock and send that to Pat to be re-keyed.
            Harry
              Ralph...
              poster's profile lists his car as a '65. Only '63-64 mid-year Corvettes used a single key... By '65 it was a 2-key system.
              • Michael H.
                • January 29, 2008
                • 7477
                Re: Keys
                Ralph,
                I agree. Even though the locks changed to a two key system for 65, the ign and door were still the same key. The second key would have been for the I.P. compartment and spare tire lock.
                • Gary B.
                  • February 1, 1997
                  • 7046
                  C1, C2, C3 Key cutting, stamping, recoding
                  Having recently studied C1, C2 and C3 keys in some detail for an article in the Restorer, my recommendation for any C1-C3 key related work is our fellow NCRS DB poster, Pete Lindahl. I recently learned that Pete can supply correct key blanks, he can cut keys, he can stamp the code numbers into the knockout, and I'm guessing that he can rekey lock cyclinders, although I'm not 100% certain of this last item. In any case, I've seen Pete's work and it is as good as anyone elses and better/more accurate than some and for those reasons I'm recommending Pete. I have no stake whatsoever in Pete's hobby business. He and I were simply co-authors on the Restorer article and during that collaboration I learned that Pete has the above capabilities. Pete can be reached at (505) 663-0995; pclindahl@comcast.net
                  Gary
                  • Gerard F.
                    • June 30, 2004
                    • 3806
                    Pete did a great job on my keys
                    and stamped the numbers in the knockout. I just gave him the numbers off my original keys at the recent Flagstaff meet.
                    Jerry Fuccillo
                    #42179
                    Jerry Fuccillo
                    • Dick W.
                      • 10483
                      Re: C1, C2, C3 Key cutting, stamping, recoding
                      Oops! Forgot about Pete. Does real good work
                      Dick Whittington
                      • Greg D.
                        • June 30, 2004
                        • 62
                        Re: Keys
                        Thanks to you all. I have located some GM blanks and the newly cut key does in fact fit both door and ignition. Thanks again for your help
                        • Dave K.
                          • November 1, 1999
                          • 952
                          Forget about the rest -- you want Pete Lindahl. Just had two sets made for my 66 and the GM Briggs/Stratton blanks are awesome. After getting feedback from many about the others-- trust me-- use Pete.
                          Dave K.
